I need a suggestion for the best oil to be put into B16A2, I use to put Castrol full synthetic 10-60, I heard it's not that good ? at least not to the B16A2 maybe good for other type of engines.
i use 5-30 mobile 1 full synthetic. when using reg oil, grit, dirt whatever fills in tiny tiny holes or anything so it wont leak. switching to a full synthetic, youll notice very very little leaks sometimes due to the small molecules.
as long as you change your oil reg. 2500-3000 miles (for me at least) you shouldn't have any problems with whatever type or brand oil.
hot places should more of 10w30 and less of 5w30, 10w30 is required as per the manual, most people only use 5w30 in the winter because it mades your car easlier to start and run on those cold winter days...
