tryagian
So the stud on my front right wheel is stripped and i need to replace it. i only want to go the mechanic as a last resort. i have read up online and there was 3 ways of doing it that i found. one way requires me to grind down my knuckle so i can slip the stud in, but i do not want to do this. scared it can ruin my bearings. the other two ways i will explain in detail
1st way(25$)
jack up car
Remove wheel, brake disc and caliper.
unscrew middle bolt holding the hub
use a hub puller(dont know what its called") and try to pull off the hub
after hub is off hammer out broken stud and put on new one
push the hub back on the bearing
ok so what i want to know if i can press the hub back on with out a press and is that all the steps?
2nd way(75$)
Remove knuckle and replace it with another one with all good studs from the junk yard
ok so is the only thing holding the knuckle in is the top and lower ball joints?
do i need a special tool for this?
and will any 96-00 civic knuckles fit on the ex or will i need it from another ex?
thank you and any diy to do with this problem will help
1st way(25$)
jack up car
2nd way(75$)
