i have a b18b1 motor with cable ls trans in my ED7. My speedo is not working. I can twist either end of the cable and see the other side spin at the same rate so i think the cable is fine. Now from what I know, since the trans is from a DA, they had a set up for the power steering that was incorporated with the VSS so the power steering would offer different levels of assistance at different speeds. So, since I dont have power steering, the set up is now definitely different, so IDK what it should be.
my guess would be that the VSS is bad, but I thought that the VSS was apart of the speedo in DA integras.
is that accurate? is it the same in Ef chasis's? what should be my next step to figuring out how to get my speedo working?
