Civic and Integra AC compressor the same?
kikidawn
i was just wondering if the AC compressor on the D ( D16y8 ) series is the same as the B ( B18b1 )series? cause i want to have my ac back on my car and there is a shop here that can make me a cheap DP so that i can put my ac back on....until i have a little bit more money to buy a good DP. But i don't have the compressor from the B motor, i only have the compressor from the D serie motor. i use it to measure the clearance and then i go to the shop and have them put the B series one on. I mean since it clear the compressor from the d series it should clear for the b series?
civic98turbo
I'm back ....
i do believe you need a different a/c bracket....in fact i'm like 99.9 % sure ..nah make that 100%
kikidawn
i know i need a different bracket. but the clearance that i us a D series should give me enough room for the b series one?
DetainedCivic
I haz SR20
When I swapped my b-series in my last coupe I used a d16y8 ac pump matted to a crv or you can use a del sol b-series ac bracket. But you can only use either of those. I think the codes are a p54 and p72 off the top of my head but you can look it up.
The bracket new is not to expensive. I found mine in a junkyard.
I also have a b-series ac pump in the garage if you need one.
As far as size goes between d and b ac pumps is I believe they are the same size. I think the wheels are a tad different in size but thats it.
qwikxr
former PCM#3
Hmm.. when I swapped my B18C into my '96 EJ6, I couldnt use my D series pump with the B18 bracket. Ended up scrounging a compressore from a Bseries. The only thing I needed to change, line-wise, with the B-pump, was use a '00 Si line from the pump to the civic line, about 12" long.. Other than that, I've got no other answers. Sorry.
DetainedCivic
I haz SR20
thats because you needed the crv bracket or del sol b16 bracket. The mounting holes are the same as a d-series pump.
xxsenceo89x
aka superman
you need the ac bracket from a 94+ honda crv. after that it will all bolt right up.
