Civic loosing clutch fluid
scheetz_21
Bought new car and got it home clutch had some play, looked had low fluid? Is there a comin wearing part? 94 ex
Subie_Love
check the clutch slave cylinder, usually located mounted on the front of the block where your engine stamp is. "clutch fluid" is essentially brake fluid located in the resevoir near the top right. fill it with some dot 3/4 brake fluid and if it still continues to drop after driving for awhile or you feel your clutch start to get weak replace the cylinder. Cost about 8 dollars and is very simple if you're not a moron. make sure you bleed it correctly because that probaby caused the issue in the first place.
scheetz_21
So I dont gotta pull the engine to put new slave in?
scheetz_21
Ok I know how to pull and bleed one now but I'm not that positive that that is what's leaking.... Should I be able to see it leaking? There is oil over on the air cleaner box and I'm not sure what might Nxt diagnosis. Step d be?
Ek_Rider
theres also a clutch master cylinder open driver door look under the dash behind the clutch pedal its on the fire wall connected to the clutch check for fluid this is only 30 or less dollars check if its leaking from there before you buy a new one
This^
MistahJuice
100% real juice
Kinda funny, I just changed my slave today, I was gonna make a DIY for it since it's simple and I wasn't in a hurry so I took some pics haha, I'll do it now but it's pretty simple to figure out yourself.
JohnS.
BANGARANG
Depending on where on the air box, that'd be quite the jump for oil. Definitely post clear pictures.
mymmeryloss
RHD is where its at
^what?
And i suggest changing the slave and m/c at the same time...
scheetz_21
My phone auto corrects... Lol I will put pics up tommarow! And y should I change both? So I don't have to bleed twice if m/c is bad?
MistahJuice
100% real juice
That and cuz having one new and the other 15+ years old can cause some issues. Check the Diy's for a how to on changing the slave, and im sure theres a diy for the master on honda tech somewhere
