Civic RS D17A, is it vtec or not?
Hondan.
JDM
I want to confirm if the D17A in the Honda Civic Ferio RS is vtec or not?
To be exact, I think it is a D17A1
Click to enlarge
This says vtec
arod52388
D17A2 = VTEC
D17A1 = no VTEC
arod52388
well then if in that pic it says it has vtec then i guess it has vtec. in that chart u posted the D17A1 is non vtec so i really dnt know wat u want.
jonathan2006
D17A2 User
no difference
d17a1 is non vtec
check the block stamp
probably just a vtec wire cover
TAZ_FERIO
7th Gen Civic
The JDM FERIO RS ran a D17A which did have VTEC (Not iVec) and still was SOHC. It ran 113 HP so just under what the D17A2 runs. The D17A was only released in japan.
TAZ_FERIO
7th Gen Civic
True, I was not throwing the a1 in the mix therefore saying that the A was just under the A2 would be just fine. Unless you have nothing better to do then be a d**k about the wording of small stuff. But thank you for the useless correction when it was not necessary, I'm glad you were there to help.
vjf915
Well would you mind explaining how 113 is just under 127? Not really. Maybe 14hp doesnt make matter much to cars with actual power, but it kinda makes a difference here.
Hondan.
Introduced in 2000, the ES-generation Civic is very different from previous generations. For this generation, Honda rationalized the line-up significantly - Civic fans were taken by surprise by the deletion of the highly regarded SiR variant ! There are now no DOHC VTEC ES-Civics, even for Japan. In its place is a line-up of refined 'executive' SOHC-VTEC Civics. As a whole, the ES-Civic is actually improved in many ways compared to previous generations - strengthened chasis, more spacious cabin, etc. For the JDM, both the Civic Ferio sedan and the Civic hatch line-ups now uses a significantly re-designed D-series engine in either 1.5l or 1.7l, SOHC, with and without VTEC. For most part of Asia, especially ASEAN, the ES-Civic line-up was similarly simplified. For Malaysia for example, the line-up comprises only 1.7l Civics, SOHC, in either non-VTEC or VTEC form. It was similar in other Asian countries as well.
http://asia.vtec.net/article/CivicRX/
Hondan.
http://www.cars-directory.net/specs/honda/civic_ferio/2001_10/12474/
GENERAL
Body type Sedan
Drive FF
Transmission 5 speed manual
Displacement, cc 1668
Frame LA-ES3
Price of new car, thousands yen (Tokyo area) 1612 (~$13400)
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4435 x 1695 x 1440
Interior dimensions (LxWxH), mm 1865 x 1380 x 1170
Wheel base, mm 2620
Treads (F/R), mm 1470 / 1465
Ground clearance, mm 150
Curb vehicle weight, kg 1110
Gross vehicle weight, kg
Seating capacity, persons 5
Doors number 4
Min.turning radius, m 5.4
Fuel tank capacity, l 50
ENGINE
Engine model D17A
Max.power (Net), kw(PS)/rpm 130 ps (95.62 kw) / 6300 rpm
Max.torque(Net), N*m(kg*m)/rpm 15.8 kg*m (154.95 N*m) / 4800 rpm
Power density 8.54
Engine type Water cooling serial 4 cylinder SOHC16 valve
Engine information VTEC horizontal ranging belt driving
Fuel system Electrically controlled gasoline injection system (HONDA PGM-FI)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) Yes
Compression ratio 9.9
Bore, mm 75
Stroke, mm 94.4
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 5.6
Fuel consumption at 60 km/h, l/100km
CHASSIS / TRANSMISSION
Power steering Yes
Tires size, front 195/60R15 88h
Tires size rear 195/60R15 88h
Braking system, front Ventilated disk
Braking system, rear Disk
Suspension system, front McPherson type
Suspension system, rear Double wishbone type
EQUIPMENT
EXTERIOR EQUIPMENT
Sunroof / Moonroof Option
Front fog lamp Not Present
Rear fog lamp Not Present
Xenon headlight (Discharge lamp) Option
Projector headlight Not Present
Rear wiper Not Present
Front spoiler Present
Rear or roof spoiler Present
ABS (Antilock brake system) Present
TCS (Traction control system) Not Present
LSD (Limited slip differential) Not Present
Privacy glass Present
UV cutting glass Present
Aluminium wheel Option
INTERIOR EQUIPMENT
Air conditioner Full automatic
Wood panel Not Present
Cruise control Not Present
Centralized door lock Present
Power window Present
Steering wheel telescopic Not Present
Steering wheel tilt Present
Leather steering wheel Not Present
Power front seat Not Present
Power rear seat Not Present
Leather seat Not Present
Falling down type rear seat Not Present
Child seat fixed with seat belt Present
Rear ELR3 point seat belt Present
Front seat pretensioner seat belt Present
Fourth limited front seat belt Present
Side impact bar Present
Airbag (Driver) Present
Airbag (Passenger) Present
Airbag (Side) Option
Audio deck Not Present
CD-player Not Present
Car navigation system Option
Colors
Color spectrum Color
night hawk black pearl
Taffeta white
Satin silver & metallic
Redy red pearl
Eternal blue pearl
Titanium & metallic
Option
Brilliant white pearl
DieMaster
why dont u push your head a couple more feet toward the winshild and see if it has the spool valve. f**k what the cover says, if it's got the sololnoid theres no disputing it.
