clutch problems
93-PHX-EG
Work In Progress
so i went out today to drive my car to work and i started my car fine and i went to shift into gear and it wouldnt go.... so i tried to put it in reverse and it was just grinding (i pulled it back out realy fast) but i got a ride to work and when i got home i popped the hood and there was no fluid in the clutch... and i looked and it looks like it is leaking on the inside where the peddle goes into the cylinder... so my Q is how do i fix it and has anyone had this happen to them before??
i have a 93 with the d15b7 and stock trany
Gstemrich
wow that is really ironic because the same exact problem happended to me today also. i havent been able to find where the leak is coming from on mine, but if i find out i will let you know.
JDM Davey
Silver Member
i would just buy a omni clutch master cylinder and a steel braided brake line. run it straight from the clutch master cylinder to the slave cylinder. bleed it. NO more leaks and you have a fresh line and fluid
masami
Anybody have anything on this? The EXACT thing happened to me this morning before school
