Cometic Head Gaskets and StreetPro Gasket Kits
Jay Jay
Administrator
Premium
Cometic Head Gasket
The Cometic MLS gasket is comprised of three layers of Stainless Steel. Cometic uses Stainless steel for increased strength, its ability to rebound and corrosion resistance. The outer layers of the gasket are embossed and coated on both sides with a flouroelastomer rubber based material (Viton) designed to meet the demands of a variety of harsh sealing environments, load conditions and surface finishes. The Viton coating is heat resistant to 2500C or 4820F.
The center or shim layer of the gasket is comprised of an uncoated Stainless Steel layer, which can be varied to accommodate multiple thickness requirements. The MLS gasket is ideal for both aluminum heads to cast iron blocks and aluminum heads to aluminum blocks.
The composition of MLS will also withstand the shearing forces created by aluminum heads on cast iron blocks. No re-torque is necessary. By design the MLS gasket promotes an even torque load across the sealing surface allowing for measurable reduced bore distortion.
Starting at $50.73 Shipped
Shop Online: http://www.tunersports.com/products/cometic-gasket/cometic-head-gasket_162.html
Cometic StreetPro Gasket Kits
Cometic Gasket introduces the new StreetPro gasket kit line for the Import Automotive Market. StreetPro gasket kits offer the same unparalleled Cometic sealing technology, used in championship winning race cars around the world, in an affordable package.
StreetPro kits are sold separately as top and bottom end rebuild kits. In the top end kit you’ll find everything you need for a head change, from the MLS head gaskets up to the induction gaskets. The bottom end (or conversion kit) will have everything you need to rebuild from the oil pan to the timing cover. Ordering the two kits together will give you every gasket and seal required for a complete rebuild of the motor from top to bottom.
StreetPro Top End kits include:
•MLS head gasket
•Intake gaskets with manifold end seals
•Exhaust manifold gaskets
•EGR gaskets (as needed)
•Valve cover gaskets
•Distributor gaskets
•Carburetor gaskets
•Air cleaner gaskets
•Thermostat housing gasket
•Intake and exhaust valve stem seals
•Throttle body gaskets (as needed)
StreetPro conversion kits include:
•Oil pan set
•Timing cover gasket(s) and seal
•Rear main seal
•Water pump mounting gasket
•Fuel pump mounting gaskets (as needed)
Starting at $63.95 Shipped
Shop Online: http://www.tunersports.com/products/cometic-gasket/cometic-streetpro-gasket-kits_472.html
Jay Jay
Administrator
Premium
Friday Bump
cmcbride07375
Anybody know what head gasket kit I need for a gsr block and a jdm b16a1 head?
