A proper tune with the right combination of parts will yield the most hp per dollar spent.dont chip a civic. your not going to get much of a gain and you gotta get it tuned afterwards so its not worth the money
You might be right saying that just a chip itself isn't worth it on a stock motor, but something that is built or has cams, etc can definitely benefit from a basemap that will get you to your tuner rather than running on the stock ecu.
Plus, having your ecu chipped now isn't that bad of an idea. You can basically use it for any setup that you do in the future including a boosted setup. So there will be no need to get another ecu if you would swap to a different engine setup, just a different chip.
