wellbuilt
OK ladies and gentlemen I just need to know which ecu and throttle body I need to get for my CRX to fix my problem. It has a jdm b16a from a 94 del sol. I just bought the car and it had a rough idle. So I took it to the shop and they said it needs a bracket for the idle and the ecu needs to be a p28 chipped obd1(currently has a pr3)and he said some other numbers. It has I/H/E stock intake plenum. The idle was really low and when I would drive it and put it in neutral it would just die out and when I would try and put it back in gear it jerked back and fourth real bad. Is it possible that these things are causing my problems?
