mine has p08-4 and its a d16z6should have a ECU code stamped on the front, around the exhaust ports. Example P28, in that case it would be from a d16z6.
the d15b is pretty much the same thing as a z6, its obviously different in the bottom end, but I do believe the heads are very similar if not the same.the thing is that i want to know if there is a way to know if its a d15b. because if i buy it it might be a z6 and thats wat i dont want
yepthey are the same head, both p08's, but I think the cam out of the d15b is a littlte bit more aggressive.
the one that im buyin is p08-2. so it means its a z6? am i right? how much would you guys would pay for a sohc vtec head?yea i just read that they are both p08's. but the d15b is a p08-1 and the z6's are p08-2,3,4,5. Depending on year and trans type.
