krillinthekie
i just started doing this swap, i got the engine ready to go back in but the timing belt side motor mount is not linning up correctly.
so here is my situation,
im putting a D15B7 block with a D16Z6 head in a 94 civic EX, it had a D16Z6 in there but stuff happened and i ended up with a rebuilt D16Z6 head and a low millage D15B7 block.
the rear motor mount seems to be linning up fine, the mount on the transmission side is rusted up but still seem to be linning up, but the mount on the timing belt side is not looking correct at all. the mount is from the D16Z6 and it has 3 holes, the engine part has three blots but there not going vertical there at an angle, its making the engine try and rotate. i took the mounting piece of the D15B7 and tried it but the two bolts on it are not parallel to the engine like the motor mount holes are.
to make this short, what motor mounts do i need for this D15B7/D16Z6(Mini-Me) going into a 94 Civc EX?
thanks a ton.
thanks a ton.
