D16A1
* Found in:
o 1986-89 Acura Integra (USA)
+ Displacement : 1,590 cc (97 cu in)
+ Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in)
+ Valvetrain : DOHC (4 valves per cylinder)
+ Fuel Control : OBD-0 MPFI
+ 1986-1987
# Compression : 9.3:1
# Power : 113 hp (84.3 kW, 115 ps) @ 6250 rpm
# Torque : 99 ft·lbf (13.7 kg/m, 134 Nm) @ 5500 rpm
# Piston Code: PG6
+ 1988-1989
# Compression : 9.5: 1
# Power : 120 hp (88.0 kW, 120 ps) @ 6250 rpm
# Torque: 101 ft·lbf (14.0 kg/m, 137 Nm) @ 5500 rpm
# Piston Code: P29 (Equivalent to PM7)
# ECU Code: PG7
# L3 Gearbox - Cable Tranny
