I have a 97 ex 4dr. Installed a radio last week and since my dash lights dont work can anybody help me with that already checked my fuses?? Please Help???
Yup. This happened to me when I first installed a head unit in my car. I forgot to plug the climate controls back in. This is where I'd check first.check the plug that plugs to the back of the heater control unit. you usually have to unplug it when you take out the old radio and put a new one in.
But my ac/heat/air still worked. Does that switch control only the lighting?Yup. This happened to me when I first installed a head unit in my car. I forgot to plug the climate controls back in. This is where I'd check first.
If I'm not mistaken, if the dimmer is "blown," then your cluster lights will not be working either. Correct?
Is that a green plug??Yup. This happened to me when I first installed a head unit in my car. I forgot to plug the climate controls back in. This is where I'd check first.
For your 91 Civic, do the same except check fuse #8 under the dash.What if the lighting for the aftermarket radio is still working? My gauges, "dummy lights", turn signals, and ac controls work but I have no dash lights or ac lights. Could it be the same issue? Mine is a 1991 though is there a difference?
