Dash removal and replacement.
hundredwatt
Hey, I removed my dash to paint it gun metal, and i don't know if i can get it back in, It looks like i may have to remove the steering wheel, I want to put it back in with a bit more finess than the way it came out, don't want to lose the new paint job you know. Someone help!
MasterShake
how the hell did you get it out without removing the steering wheel?
hundredwatt
I am not sure, I worked it around for about an hour, and was no closer to getting it out, then all of the sudden it popped out!
MasterShake
wow umm, i guess taking the steering wheel off would be a good start, and wrap the corners with painters tape.
hundredwatt
I wound up having to drop the steering column to the floorboard since i had no wheel puller, i tried to force it in like it cam out, wound up with a spider cracked windshield. DO NOT FORCE IT, to anyone who reads this.
12.8:1 Ls/vtec
IT'S OVER NINE THOUSAND!!
A steering wheel puller is very inexpensive and easy to use. You should be able to get one at advance auto parts.
hundredwatt
Plastic and vinyl. I just used engine paint for the green, and duplicolor for the gunmetal, gonna take it back out and spray about 5 coats of clear on it in a few days. I didn't get a single paint flake for the whole installaion, removed, painted, and reinstalled all interior from 5 today until 2 am.
You can take the steering column dash bolts off and pull the column down enough to get the dash over the wheel. The gunmetal, and green was an awsome combination!
EG_CaSe
ScAre CrOw
i havnt needed to use one so far.. just 1 or 2 good pulls and the wheel pops right off.
NOFX
I'm NOT eran!
:werd: I'm not sure if I could get my wheel off, but i've seen a couple different guys manage to pull it off when needed.
Jas0n
What's up dogz!!!
go to autozone and rent one for free
buzzbombtom
captin sleep0
you do not need a wheel puller to put the dash in or out. it just takes time to put it in and take it out.
Inigo Montoya
powered by boost
:werd: dash removal / replacement and steering wheel replacement is a breeze.. its when you get into the dash conversions and/or 8pt+ rollcage install.
Vt22ec
How do you drop the steering colum ?
