Purchased this 97 Ek coupe Hx model about 2 weeks ago and it has a few things wrong with it. I started messing with the driver speaker because it wasn't working. I checked for continuity on the speaker wires and didn't have any. Sooo, i took off the driver side fender and unplugged the door harness and as i pulled back the rubber boot, wires were separating from the harness connectors. (about 4 wires) The harness was covered in white grease "i Assume for corrosion" so i couldn't tell where the wires that separated came from. Has anyone came across this problem and if they did what did they do? Is there a replacement harness that i can splice in replacement of the original? II was considering of hard wiring the doors with some nice connectors so if i do need to remove the door in the future i can. Any suggestions???
