door locks
codyj86
How do i remove the "safe guard" or whatever you want to call it, from the drivers door lock? Where in order to lock it from the inside you need to pull the handle and hold it out 1st then lock it? i'm reeeeallly sick of doing that. and i want to put in power locks and this might make it a bit easier.
jokenfu21
i installed a keyless entry/power door locks alarm on mine you won't have to worry about it until the battery need to be changed.
Bangin' HB
surfing member
you dont need to pull the handle when the door is closed. so you dont have to mess with it if you dont want b/c you can just get out of the car, close door, then lock it and it will work fine.
Tom
honda.co.jp
your right he doens't have too, but it's a honda fail safe way of not locking your key in the car if you lock it from the outside, instead of locking by using the handle.
codyj86
ya, i forgot that i don't have to pull the handle if the door is closed. thanx...
