VC? What dat is?black magic engine bay cleaner worked really good. but if you have a diy painted vc then tape it off or something because it left little spots on mine but it really worked good.
Ah yes. Should have known that!valve cover i'm assuming
x2 i use it.SImple Green works well and it smells good. lulz
yeah. sorry. vc=valve covervalve cover i'm assuming
I've never used an engine cleaner, what should I NOT spray. or what should I cover before cleaning it other than the alternatorx2 i use it.
if you have an open filter, that an obvious one. i always cover my distributor as well. also if you dont have a fuse box cover, cover it. thats the main stuff.I've never used an engine cleaner, what should I NOT spray. or what should I cover before cleaning it other than the alternator
you really got to be careful with pressure washers. they can force water through small areas. i always just use a low pressure garden hose. a pressure washer could force water into your dizzy, or even into the spark plug tubes.Engine bays dont like pressure washers. They do a pretty good job but pretty risky. It stripped off the crinkle paint on my brothers VC and ripped a small hole in the open-element filter. It would whistle at times, really annoying.
