Mechanic—Newbie
I replaced the battery, distributor cap(not the rotor tho)(should I look into that?) seen someone else posted about they changed their rotor in their distributor. New spark plug wires, Changed the MAP sensor.
I start the car, runs like a dream, but when gas is applied, regardless of pressure, it’s boggs the motor down to almost nothing, then when I let off the gas, it’s comes back to life like nothing changed. I can’t rev it at all, if anyone has had this issue, please help a brotha out! But I haven’t listened for the “fuel pump to prime” so that’s what I’ll be doing when I get back to the car. If that’s a possibility, does it mean the fuel pump is working since it starts the car?? Any advice helps, thanks in advance everyone!
