So I checked out a 00 civic ex with a b16 motor in it and it was idling high around 1500. Should I get it and if I grab it will it hurt it driving it like that? Thanks.
1500 isn't bad, it should idle 1200-1500 cold and 700-1000 warm. You can always turn the idle adjustment screwSo I checked out a 00 civic ex with a b16 motor in it and it was idling high around 1500. Should I get it and if I grab it will it hurt it driving it like that? Thanks.
True or maybe a little vacuum leak.. Make sure it don't have a check engine light on.1500 isn't bad, it should idle 1200-1500 cold and 700-1000 warm. You can always turn the idle adjustment screw
