ll0SCRAPPY0ll New Member Jun 7, 2010 #1 My 93 ex is overheating. It has 249,XXX. I notest antifreeze on the ground on the drivers side of the car. Does the water pump leak when it goes bad?
RonJ Banned Jun 7, 2010 #2 ll0SCRAPPY0ll said: My 93 ex is overheating. It has 249,XXX. I notest antifreeze on the ground on the drivers side of the car. Does the water pump leak when it goes bad? Click to expand... It's almost surely a bad water pump, especial if coolant is leaking from the weep hole at the bottom of the lower timing belt cover.
ll0SCRAPPY0ll New Member Jun 7, 2010 #3 Are the water pumps hard to do? What else should I change when I am doing the water pump?
RonJ Banned Jun 7, 2010 #4 ll0SCRAPPY0ll said: Are the water pumps hard to do? What else should I change when I am doing the water pump? Click to expand... The difficult part of the job is removing the dreaded crank pulley bolt. While the pulley is off, consider also replacing the timing belt and belt tensioner, as well as the camshaft and front main oil seals especially if they are leaking.
