To get the master bushing set put in you are looking at about 10 or so hours labor at a shop...much more at home with a torch. And I wasn't looking for a thread...just stating that it is a pain in the ass.
So far I have the swaybar bushings, endlinks, front/rear damper shaft bushings, front/rear upper spring isolators, steering gearbox bushings, shift stabilizer bushings, rear trailing arm bushings, and the rear bushings on the front lower control arms installed. All are the black graphite impregnated ones. I am halfway done burning/cutting the O.E. ones out of the front lower arms, then all I have left are the bushings in my SPC front camber arms. The only thing I have had a shop do is press in the rear trailing arm bushings once I had the old ones out and the shell polished.
Very labor intensive, but very satisfying to do it yourself too.
few pics of the fun so far.
the rear trailing arm took the most time
bottom pin was not polished yet
I also had some trouble with the front lower ball joint...so I ordered a knock off of the Honda tool for $14...saving $135 on the $150 HG one.
You get what you pay for though...it ripped the boot
and broke
I finally got it apart though and the bushings in the front lower arm were shot
On the steering rack I actually had to get inside and disconnect this joint to get it to drop down far enough to get the old ones out.
there are more but I have wasted enough bandwidth. lol
These things are a b***h though...they better be worth it.
