Isnt fuel cutoff 8300????? How the hell did u get it that high?
thought i already said this, yea it stops at 8200, but if your VTECing 3rd and throw it in 2nd, the engine has to spin that fast no matter what fuel its not gettinMySiIzFaster said:Isnt fuel cutoff 8300????? How the hell did u get it that high?
so you're saying the engine will run above the fuel cutoff because the engine is just going that fast?aemkitfox said:thought i already said this, yea it stops at 8200, but if your VTECing 3rd and throw it in 2nd, the engine has to spin that fast no matter what fuel its not gettin
The momentum of the car will push the engine past that point. Without a "Jake Brake" or something you could cut air, spark, and ignition and keep an engine spinning provided you had a steep enough hill to run down or something pushing or pulling the car. Just cutting the fuel doesn't immediately effect momentum.Zak8022 said:so you're saying the engine will run above the fuel cutoff because the engine is just going that fast?
that doesnt make any sense. fuel cuts and rev limiters stop the engine from gaining any more rpms when someone f**ks up. if there's no fuel.. the engine wont continue running, and it most definately wont continue to raise in rpms.
maybe im misunderstanding you... if i am, please... explain what you're sayin.
