Why is that Daniel?Originally posted by SeanJohn1802
Front - Kumho 712's 205/55/15
Rear - Kumho 712's 195/55/15
Originally posted by thoughthard
205-60-15
Kumho 716 Ecsta HP4
Choices were either 195-60-15 or 205-60-15. Both of them kept the speedo around the correct reading. The 205 was chosen because:Originally posted by SeanMc300
get a 50 series!
205/50-15 yokohomo avs es 100's
next tire is falken azenis is same size
seanjohn, atleast my reasoning for this, is because the back end will rotate better around the turns if it has less of a contact patch to the ground compared to the front. its an anal way of trying to overcome understeer.
As long as the speedo isn't beyond 4% off, your speed readings will be fine.Originally posted by thoughthard
-More tire width to protect the wheel lip
-Lighter than the 195-60-15
-Less miles on car with the larger tire (even though it is miniscule)
