Flucuating Idle
Dont_Tri
Just recent my car has been idling weird get's like a hick up and jumps up to 1100 then back down to stock idle. Thise occurs when I come to a stop at a light or just a normal stop. IIt dles then hick up to 1100rpm then back down. May jump up again but settles again at stock idle. WTF any ideas guys?
96733
maybe iac valve?
simmons
i had this for ages.. soo annoying and embarrasing.
i had a diagnostics done by honda, who determined it was the iacv (idle air control valve). i got it fully cleaned out, and the problem's gone. luckily i didn't have to replace it completely.
Dont_Tri
Thanks I have located it here on this little diagram I will remove it and clean it out and reset ECU.
simmons
yeah, that's the right part.
i'd only remove and clean it yourself if you definitely know what you're doing - i had mine done by a garage.
also, it might be worth getting it checked out to make sure that it definitely is the iac valve causing problems, or you'd be completely wasting your time! i guess we'll soon find out..
simmons
for my engine (D14A4) it is 16022-P2A-J01
dunno if that's the same across the board, or if it's specific to my engine.
Going-West
Tree people on my radio
My car is doing the same thing, I replaced the IACV and it didn't do a thing. For the most part, weird idles are caused by:
Bad IACV
Vacuum leak
Bad MAP or TPS sensor
FITV valve
I don't think my sensors are bad, couldn't find a leak, and it's not the IACV. I'm going to try my FITV valve. Heres some HT threads on it:
http://honda-tech.com/zerothread?id=1003988
http://www.honda-tech.com/zerothread?id=1564019
If you fix yours let me know what you did because it's getting really annoying lol
gearbox
make sure to do the ecu reset and idle learn after reinstalling the TB and sensors or the car will idle like crap.
