because lots of people have made that horsepower, so its pretty common to say he needs s 255lph fuel pump (becaue its common) and injectors. He dosent need a fuel rail, and he dosent need a fuel pressure regulator.This is what frustrates me. A guy is trying to build his engine and wondering what parts to get and everyone gives him answers, but no rhyme or reason as to why.
Here are the facts:
Desired HP: 250
Desired PSI: 10
B.S.F.C.: .60
Safe Duty Cycle: 80%
Finding Injector Size:
(250HPx.60B.S.F.C.) over (4# Inj.x.80Duty Cycle) = 46.87lbs./hr per injector of fuel.
46.87lbs./hr = 492.13cc/min.
This means the you need at least 492.13. and at 10 psi, the new flow rate of those injectors will be 528.5cc/min.
Finding needed fuel pressure.
43.5stock FR+10 boost+5 assumed pressure loss= 58.5psi of fuel, but a straight 60 to be safe. But be warned that fuel pressure loss can be up to 10psi., so 65-70psi would be safer to run.
If your stock FRP can run it, then go ahead and use it, but that is highly doubted.
FRP: 65 to be safe
Required Fuel: 150lbs/hr
150lbs/hr = 23.66gal/hr
At 65psi FRP and 23.66 gal/hr, a 190ltr/hr Fuel Pump is needed.
Also, you can go above 80% duty cycle, hell...you can go 100% duty cycle. The chances of the injector failing are slim.
