i sprayed a d16y8 for YEARS.. put over 1000lbs of nitrous through it.. ran one step colder plugs.. and only used premium gas, never really had an issue.. blew up a couple trannys but the motor held...
if you do turbo, super charger, OR nitrous improperly you WILL blow the motor, if you get greedy and try to push too much power through the motor you WILL blow it up...
a mild shot of nitrous is no more dangerous than low boost.. the advantage to nitrous is as you drive the car around normally you can retain a very stock streetable car...
