Everytime I put my car in reverse with the clutch all the way in it makes a grinding sound. Also while accelerating faster then normal, I sometimes grind 1st to 2nd even with the clutch all the way it usually happens 1 every 5 times I'm stepping on it. All my other gears are fine no problems that I know of. Also is there a way to get into 5th faster. I'm used to it now, but it's a hard gear to get into rushing. Like you have to pop into neutral slam it to the right then up, rather then the other gears where it just a little push and it goes where I want it to.
