Headlamps electrical wiring diagram
ALEXSAN
Could you help me:?: I have a Civic 5th generation, I need the electrical wiring diagram for mount the new headlamps, high /low beam separated, (H3 and H1 bulbs). see the pic. thanks
ALEXSAN
i need the manufacturer manual! if it is possible in pdf..
slambed_civic
a test light will do WONDERS for you!
if you dont have one, i cut this from my pdf manual
ALEXSAN
someone konws, how to connect this?
slambed_civic
you will need to take a paid of pliers and pull the gold tabs out of one of your old headlight plugs. and put them where you need them
the relay should have come with the wiring harness. Im not sure of a number that you need to make them work but they are 4 prong and rectangular.
hope this helps
ALEXSAN
The wires "power" connect to? under hood fuse/relay box?
The wire "not sure" connect to? could it be? thanks
with this harness, the hi/lo headlights system will work at the same?
slambed_civic
what i did with mine years ago was just run the 2 power wires straight to the battery.
not sure.... means, i dont know what its for. i ran into the same issue when i bought cheap headlights, they didnt come with any diagrams.
