i want to replace my headlights.. but idk if i really have to take off the front bumper. Do i have to remove the entire thing?
No .... it's not. Once you've done it, it's like riding a bike. I can have my bumper off in 5 minutes, and back on in about 7.have fun aligning it back on though, its a b***h :[
+1 this kid knows whats upyeah, it is pretty painless though. 1 philips screw on each corner under the fenders, 7 clips on the grill, and i think like 2 10mm bolts on the bottom. actually you dont even have to take the bolts off the bottom, just remove the 2 screws and 7 clips then pull the bumper forward so it slides off the bumper support and hangs down. each headlight has 4 10mm bolts
replacing the headlight should take you 10-20 minutes. after the first time you can do it in about 5 minutes
Damn, youd called Fail on yourself hahaI'm a noob and replaced my headlights with bumber still on. Fail.
this kid knows his s**t lolyeah, it is pretty painless though. 1 philips screw on each corner under the fenders, 7 clips on the grill, and i think like 2 10mm bolts on the bottom. actually you dont even have to take the bolts off the bottom, just remove the 2 screws and 7 clips then pull the bumper forward so it slides off the bumper support and hangs down. each headlight has 4 10mm bolts
just take your time and you should be goodhave fun aligning it back on though, its a b***h :[
Well I have lovely pics up of my dent in my build hahaoh well..a dent in your car isn't much when you left you car running all church long..a good hour and a half...
oh and your doors where all locked so you had to wedge the door open with a screwdriver, leaving dents on the door and damaging the seal, so that you could reach in with a close hanger to pull the trunk lever
we were late..didn't have time to turn it off and i didn't want it to get stolen..???
jk
still feel retarded to this day about it haha
at least it is a good conversation starter
