None2Slow
It sounds like you plugged the radiator by flushing it. Did you back flush, or just drain and fill? As for no heat, have you checked at the base of the windshied for leaves plugging up the air inlet? Also, if you pull the blower motor you may find leaves in the "squirrel cage". Do you see the blend door actually move? It is possible for the linkage to move, but the door to be broken loose.
