+1Try checking the compression in the cylinder. Could be a problem with valves, valve seats, or the piston rings.
amp probe .Can you get access to a tool that will show if the power is flowing to the spark plug? I forget the name of it but I've seen it work. it goes in series with the cable and the spark plug and flashes every time a pulse is sent to the spark plug.
