check all your hoses on the intake manifold...if ones cut or detatched....
other than that...no idea
moparfan said:did you check valve adjustment? cam timing?
If possible do a leak down test.. The car i was having trouble with has 2-4 messed up valves.. not sure if they are bent or not but it did read alright on the compression test.. they read between 130-140, i wasnt there so i dont know exact numbers..tocivic said:Thanks for all your suggestions! I bought a comrpession tester today and found the following at wide open throttle while cranking the engine:
1) cylinder #1 has 100psi of compression
2) cylinder #2 has 100psi of compression
3) cylinder #3 has 130psi of compression
4) cylinder #4 has 80psi of compression
Thanks!
