Well i bought a P28 EUu that is chip with Chrome and base map for turbo...what i was told. But anyway i got the OBD2b harness today and i went and put the ECU in then took it for a drive then ran into 2 problem....1. The car now idle at around 1500 rpm. 2. I can not go over 4100 rpm it seem like it is hitting the limiter! all gears does it! Does it have to do with, before i got the ECU i was running the stock ECU and the timming was retarded, would that be a problem? I can turn it back to stock timming and see it that would help! Plus can i use this wire to hook up my ECU to my laptop???<br>
