gantt
I pulled the head on my 1.5 liter. Had low compression on numbers 3 and 4. Thought I had a timing issue. Belt was approximately 4 teeth off on cam gear. I bought car not running. Took the head to be inspected and had bad seats. No bent valves. So I think this was more of an overheating issue. Head was rebuilt. Engine is in time. I have fuel pressure, spark. Will not fire up. Tried some ether, no luck. Going to re do the compression check now. I don't see any wires loose. Hoses tight. Please give me some help! I put my money in this car and I don't have a back door plan.
OK compression test.
1, 175 psi
2, 165 psi
3, 180 psi
4, 180 psi.
Going to recheck valve lash. I thought maybe I had installed the distributor 180 degrees off, but seems it only fits one way. So I have spark, compression and fuel. It has to be a timing issue. Either camshaft or ignition timing. Timing is on mark. What am I missing here?
1, 175 psi
2, 165 psi
3, 180 psi
4, 180 psi.
