I am planning on boosting very soon and was look at the hondata engine management. It says that i must get OBDII to OBDI adapter harness,which i found, and also says i must do a OBDI ecu swap.
The conversion harness is to convert your OBDII harness to an OBDI harness... so you can plug it into your OBDI ECU.. such as a P28.
You can buy both of them from www.phearable.net.
From Phearable.net them you can get a P28 ECU with Hondata S300 installed into it already and add the boost control option for down the road when you boost it. They also sell the OBDII to OBDI conversion harness as well if you have not already purchased one.
I've dealt with them in the past and they have great customer service!
