how many pounds of boost should i run
boostedjd
I have a d16a6 motor and have a metal headgasket, eagle h beam rods, je pistons, underdrive pulleys, big 16g turbo, ported and polished exhaust side on head, valvetrain is stock....was thinkin about runing 15 pounds?
DarkCreep
D16Y8+T
Dont pass 300whp unless you do stuff to your head. Under 300whp is still a crapppp ton of fun!!
boostedjd
Don't think ill have valve float or break a spring at high rpm runnin 15 pounds on a stock head?
boostedjd
Ya already did that w my last motor..got 900 hp eagle h beam rods so if I break one of those only on 15 pounds I got some problems
got traction
i rock the sohc
you should be able to make 300 with 15-20psi. upgrading the valve train and cam will help make the same power at lower boost levels though
