How many quarts of oil do i need? 04 civic
khanhfat
Just got my 04 civic and tried to change oil myself... it got 55k on it. What type of oil should i get how many quarts? and what filter you recommend to get.. FRAM oil filter is out of the list here.
Thanks!
oddeb707
R.I.P Stephen Jackson
just get honda filter and like 4qts. i use castrol.
pmac193
Thundermuff
Read your owner's manual, conventional oil will be fine, and do not overfill that is worse than running a little low. The oil change is one of the simplest things you can do to maintain your car.
Kaotic_Zeus
Most hated man
Mine always takes 3.5 quarts with filter change even though it says 3.7 including filter. That's as exact as i can get when changing my oil. I have an EX (d17a2) the VP/DX/LX (d17a1) takes 3.5 quarts according to the manual..
I use mobil1 full synthetic/oil filter
Use any oil filter except for Fram, i'm not sure if OEM is fram (honeywell)anymore or not. :what:
remember to check the level of the oil when the engine is cold. Check it in the morning or wait a couple of hours.
toneekay
Rubbin on yo booty
mobile 1 filter, mobile 1 oil, mobil 1 ftw!
Beelzebubba
SubGenius Member
Last time I checked, Honda OEM filters were still made by Honeywell. The same company as Fram.
Fram is pretty much universally hated on every forum on the net. Even the Kia guys hate Fram and their cars are pretty much disposable
So you can go spend $5 on a Fram, $10 on a OE, or Mobil 1 or $3 on a SuperTech at WalMart.
The Mobil1, Bosch and SuperTech filters are all made by Champion Labs. I've been using SuperTech for years without problems. Externally they are identical to the Mobil1. I think the Mobil1 uses exclusively synthetic material inside whereas the SuperTech is only semi-synthetic.
EF Honda EF
those things take just over 3.5 quarts. I would go with modil 1 but if you dont want full syn then definitly use castrol and i think those take 5w20. it should be on the oil caps. may be 5w30
toneekay
Rubbin on yo booty
5w20, 3.7L of oil
Genuine Rolla
Its PETEY PETE, y0!
I use fram filters...haven't had a problem with them.... :what:
Szady
D-Series Master
:lol::bluelol:
He said seven!
Let's just fill it until it overflows from the filler cap!
Word. Filling the motor up w/ oil till if flows outta the valve cover is mad tyte JDM, y0!
