How To: Install Exhaust Wrap by Mishimoto
Discussion in 'Engine Tech / Drivetrain DIY How-To's' started by Mishimoto, Jan 25, 2010.
Thread Status:
Not open for further replies.
  1. Mishimoto
    Mishimoto Product Manufacturer 5+ Year Member
    Apr 3, 2009
    175
    Wilmington, DE
    DIY Guide – Heat Wrapping your exhaust manifold
    Since we at Mishimoto love to see our customers happy, we wanted to show you how to wrap an exhaust manifold with our new Mishimoto Exhaust Wrap. Click the link to see what the wrap can do for you!
    http://www.clubcivic.com/board/showthread.php?t=181344
    The manifold we are wrapping today is a 4-1, 2 piece, Honda D16 (4 cylinder) header.
    [​IMG]
    Step #1 – Cleaning and Preparation
    Clean off any and all dirt, oils, or anything else that may have made it’s way onto the surface. We sprayed it down with Simple Green, cleaned it, and then wiped it down with a cloth and Brakleen.
    [​IMG]
    Step #2 – Starting the Wrap
    We started with the downpipe first. Unroll about 2 feet or so and make the first wrap. Put some zip ties on it to prevent the wrap from moving.
    [​IMG]
    [​IMG]
    [​IMG]
    Step #3 – Wrapping
    Begin to wrap tightly around the exhaust piece while pulling on the wrap itself.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    *Remember to continually pull on the wrap to keep it tight!
    **Make sure you over lap about a ½”**
    [​IMG]
    When you get to a bend, you must pull the wrap in order to get any creases, overlaps, and folds out!
    [​IMG]
    [​IMG]
    **We found it would be easier to wrap while the o2 sensor was installed. This prevented us from getting any of the wrap stuck in the threads.
    [​IMG]
    [​IMG]
    Apply zip ties to hold it in place. Almost done!
    [​IMG]
    [​IMG]
    Step #4 – Finishing the Wrap
    Take a steel tie, put it around where you started wrapping.
    [​IMG]
    Now, get a buddy to help. Hold the silver piece, and pull on the black steel to tighten the tie. We used pliers to do this. Once tightened, fold the extra back over the silver piece and then push the metal “clips” down to hold everything in place.
    [​IMG]
    Now repeat step #4 where the wrap ends (at the other side of the exhaust piece). Cut off the extra that’s left over.
    [​IMG]
    Done the downpipe!
    Step #5
    Now, repeat steps #1-4 for the upper piece. Remember to keep it tight! The more bends the manifold has, the more of a chance a fold, or flap can develop! We found it was easier to unroll the remaining wrap and pull it all through with each pass.
    [​IMG]
    Pulling the wrap through:
    [​IMG]
    Try to do as much wrapping as possible without stopping. We chose to go down runner #4, and up runner #3 and cut. Then, a separate piece going down runner #2 and coming up #1. This was the preferred method rather than wrapping each runner, then cutting when we got to the end. Not mention, you would probably run out of the steel ties, too.
    [​IMG]
    Both #3 and #4 runners wrapped, and tied.
    [​IMG]
    Now, begin wrapping the remaining runners of the manifold the same way.
    [​IMG]
    Manifold is now done!
    We then bolted the two pieces together and we were finished! Here are some pictures of the final product.
    [​IMG]
    [​IMG]
    [​IMG]
    Be sure to check out our Mishimoto Exhaust Wrap in action! Click the link below:
    Thanks!
  2. Jersey8
    Jersey8 B20: Detroit Muscle! Registered VIP Registered OG 5+ Year Member 10+ Year Member
    Mar 4, 2006
    4,690
    MI
    heres a little trick, put the wrap in a bucket of water and get it wet. this allows you to pull the wrap tighter, and when it dries it tightens up really good. this provides a better looking finished product and reduces flaps and breaks
  3. militition
    militition New Member
    Sep 24, 2010
    2
    richmond va
    exhaust wrap
    Any one have any experience with Taylor Cable products? i was curious if it really drops air temps under the hood.
  4. aeraiva
    aeraiva Dedicated Civic Owner
    Dec 7, 2012
    99
    Portland, OR
    Agreed and recommended.
  5. aeraiva
    Dec 7, 2012
    99
    Portland, OR
    To add to it, note that your header wrap will give off smoke when you start driving. This will continue for a few full cycles (warm up/cool down) or up to about a weeks time. It is completely normal and will eventually stop. It's part of the curing process so don't go thinking your wrap is gonna go up in flames. It won't (unless you got some really crappy off-brand wrap for dirt cheap).
  6. CALIKID
    CALIKID New Member
    Oct 4, 2014
    1
    CALI
    good write up. i was going to to this to my headers thnaks
  7. barcasmith
    barcasmith Banned
    Nov 26, 2014
    4
    CA
    Excellent tutorial, gonna try this out..
Loading...
Thread Status:
Share This Page
