a catch can or a breather box?can anyone let me know how to do this?
next is the catch can to the Valve Cover!!
u can have fittings welded in you cover to run hoses to like i did!
orrr
u can run a small hose to the stock breather port on the back of the Valve Cover near the oil cap!!
and Vibrent sells a part that mounts under the oilcap itself that had a fitting that u can run a 2nd hose to!! (kind of like a LsVtec sandwich plate, and the oil cap is like the oilfilter, and the plate has the fitting/s)
and the can is just to hold misty oil (blow-by)!! so u can use anythinggg.. Ebay got Tonssss for cheapppp.. i used a Coke Can for a longg time.. lol
ORRRRRRRRRRRRRRRRRR U CAN BE A BALLER , and get the T1 catch can!! it's a one stop shop Item!!
it has a large catch can that has enough ports to run hoses to the block andd the Valve Cover and also return the spent oil back to the block.. cost about $599 with hoses, fittings and box!! (( it mounts where the stock battery would be , so the battery will need to be relocated))
this is a T1 catch can on my friend's car
