How To: Reading Check Engine Light (CEL) With Code List
Discussion in 'Engine Tech / Drivetrain DIY How-To's' started by lonewolf, Apr 2, 2005.
  1. lonewolf
    lonewolf New Member Registered VIP 5+ Year Member 10+ Year Member
    Jan 12, 2004
    300
    England
    199?-2000 models
    All models are equipped with an On-Board Diagnostic system (ODB). This facility is built into the PCM, and is designed to alert the driver to a system component fault which may result in a higher than normal emissions of harmful exhaust/fuel vapour gases and speed up the engine management troubleshooting procedure. Should an engine management component fail, the incorrect (or implausible) signal is recognised by the PCM, which stores a Diagnostic Trouble Code (DTC), and where appropriate, illuminates the Malfunction Indicator Light (MIL)/Check Engine Light (CEL) in the instrument cluster.
    In order to retrieve any stored DTC's, either a fault code reader must be connected to the vehicles datalink connector (located above the Service Check Connector), or read from the MIL in the instrument cluster.
    [​IMG]
    The service check connector (2-pin) is located under the dashboard, above the passenger side kick panel. By default it is inserted into a green rubber housing. for 92-95 models it is gray, 96-00 models its blue. The codes can be read by bridging the two pins in the service connector and reading the MIL on the instrument cluster (all models). Vehicles 2000 onwards are fitted with a 16-pin diagnostic behind the centre console on the passenger side. A fault code reader is required to retrieve or clear codes via this connector.
    To view any DTC's stored in the PCM memory (without a code reader), fit a bridging wire into service check connector then turn the ignition switch to the ON position. If any codes are present, they will blink a sequence in the MIL to indicate a system or component failure.
    [​IMG]
    The MIL will blink longer to represent the first digit and then will blink short for the second (for example 1 long and 6 short would be code 16). If the system has more than one problem, the codes will be displayed in sequence, there will be a pause, then the codes will repeat.
    When the PCM sets DTC, the MIL will come on and trouble code will be stored in the memory. The trouble code will stay in the PCM until voltage to the PCM is interrupted. To clear the memory, remove the BACK-UP fuse from the fuse relay box located in the engine compartment for at least ten seconds. NOTE - This will also clear any radio presets/codes.
    Common Diagnostic Trouble Codes
    1 O2A - Oxygen sensor #1
    2 O2B - Oxygen sensor #2
    3 MAP - manifold absolute pressure sensor
    4 CKP - crank position sensor
    5 MAP - manifold absolute pressure sensor
    6 ECT - water temperature sensor
    7 TPS - throttle position sensor
    8 TDC - top dead centre sensor
    9 CYP - cylinder sensor
    10 IAT - intake air temperature sensor
    12 EGR - exhaust gas recirculation lift valve
    13 BARO - atmospheric pressure sensor
    14 IAC (EACV) - idle air control valve
    15 Ignition output signal
    16 Fuel injectors
    17 VSS - speed sensor
    19 Automatic transmission lockup control valve
    20 Electrical load detector
    21 VTEC spool solenoid valve
    22 VTEC pressure valve
    23 Knock sensor
    30 Automatic transmission A signal
    31 Automatic transmission B signal
    36 traction control found on JDM ecu's
    41 Primary oxygen sensor heater
    43 Fuel supply system
    45 Fuel system too rich or lean
    48 LAF - lean air fuel sensor
    54 CKF - crank fluctuation sensor
    58 TDC sensor #2
    61 Primary oxygen sensor
    63 Secondary oxygen sensor circuit
    65 Secondary oxygen sensor heater wire (black wires)
    67 Cat Converter
    71 random misfire cylinder 1
    72 random misfire cylinder 2
    73 random misfire cylinder 3
    74 random misfire cylinder 4
    80 EGR Valve/Line
    86 ECT sensor - Cooling System
    91 Fuel Tank pressure sensor
    92 EVAP Solenoid/Valve/Vacuum Lines
  2. NoWayBack91Si
    NoWayBack91Si New Member Registered VIP 5+ Year Member 10+ Year Member
    Jan 20, 2005
    2,349
    Ohio
    just curious...why is code 3 and 5 the same?
  3. DaGFTDOne
    DaGFTDOne Car Audio Guru Registered VIP 5+ Year Member 10+ Year Member
    Sep 10, 2004
    2,599
    Williamsport, PA
    To answer for anyone else who might ask it probably is for a high or low voltage output. What that means I can't remember but it should make it more clear.
  4. leachuan
    leachuan New Member 5+ Year Member
    Jan 6, 2008
    3
    Malaysia
    it started with a short one, then 2 long and 2 short. Is this showing code 1 and code 22? Pls advise
  5. DaGFTDOne
    Sep 10, 2004
    2,599
    Williamsport, PA
    Yes, not sure what to say for 1 but for 22 check your oil. Low oil pressure will trip it. I found that out cause mine was burning oil badly when I got rid of it. If I forgot to fill the oil it would trip that code.
  6. highrollercivic
    highrollercivic New Member 5+ Year Member
    Apr 9, 2008
    4
    omaha,ne
    how do you reset the ECU after fixing the problem, i have the service manual and followed how to do it on there but the code is still on
  7. mu$h
    mu$h New Member 5+ Year Member
    Feb 28, 2008
    2
    leicester
    hi iv got a honda civic 1995 1.3 dx and am having problems fitting in a piperX air filter because i cant get a pipe that is big enough to sit on the carb can any1 help???!!!!!
  8. Unuzual Kustum
    Unuzual Kustum 4DR Sleeper Registered VIP 5+ Year Member
    Dec 24, 2007
    452
    Hedgesville, West Virginia
    does this work on ODB2 to OBD1 converted vehicles with the OBD1 in?
  9. EluSive2K
    EluSive2K OG Club Civic DJ!!! Registered VIP 5+ Year Member 10+ Year Member
    Nov 28, 2003
    1,580
    Da Bay!!
    okay... im confused. I got 1 blink, pause, 1 blink, pause, 7 blinks, pause, 16 blinks...... then it starts all over.. is that a code 1, 16 and 17? or am I all wrong? Please let me know.
  10. EluSive2K
    Nov 28, 2003
    1,580
    Da Bay!!
    is it the oxygen sensor, speed sensor, and injectors????
  11. EluSive2K
    Nov 28, 2003
    1,580
    Da Bay!!
    Dang... guess this is not the same clubcivic I used to be a part of...... Well.... Guess I will have to seek answers to questions elsewhere. See ya around guys. =)
  12. Tom8
    Tom8 New Member 5+ Year Member
    Jan 14, 2008
    18
    California
    i think you have a few different engine codes, i think the first one is 27. the 2nd one is 16? hopefully this helps but i dont know.:lol::lol::word:
  13. Tom8
    Jan 14, 2008
    18
    California
    stand corrected, there is no 27 error code so try to count the first set of flashes again.
  14. 92BuBBle
    92BuBBle New Member 5+ Year Member
    Jun 23, 2005
    5
    Queens NyC
    what does it mean when the light doesnt blink when u jump it.....
  15. maguiver77
    maguiver77 New Member 5+ Year Member
    Nov 16, 2008
    1
    CA
    2000 civic code : 6 blinks Problem
    Ok guys have a question for you. I was driving on the freeway and noticed my check engine came on. Then noticed that my water temp was pegged. I pulled over immediately and noticed steam. I popped the hood and noticed coolant all over the place. The radiator cap was not hot so I figured I blew a hose. I popped the cap and no coolant. So after letting it cool down for a bit a added some water and it started steaming. I put the radiator cap on and noticed steam coming from the engine ( it appeared to be from the engine) Couldn't really tell. After starting the car there was no smoke coming from the exhaust so I dont think i blew a head gasket. What do you think?
    After getting towed home, I jumped the 2 pin connector and got flashes( 6 - ECT Sensor (Engine Coolant Temperature). Now could a faulty sensor cause the ecu to do something and make it over heat, or did the sensor go bad from the over heating?
    Anyone ever have a problem like this? Could a thermostat be the problem? Thanks for any help.
  16. 95 EJ Coupe
    95 EJ Coupe New Member
    May 20, 2008
    61
    Kingsville, Ontario
    Your ECU can't/will never tell your engine to dump coolant. You have a serious problem though. Check your water pump.
  17. JustJustin
    JustJustin New Member Registered VIP
    Oct 12, 2011
    443
    North Carolina
    Hey guys my CEL light came on and showed this code:
    I replaced my oxygen sensor and the CEL came on again with that code. is the o2 sensor I bought faulty? it was a cheaper brand... or would it have something to do with the wiring to the sensor. I also noticed that there are these codes:
    so does code 41 necessarily mean it's the o2 sensor that's faulty or is it something else? I imagine that if it was the o2 sensor that was messed up it would show either code 1 or 61. Any help on this would be greatly appreciated.
Loading...
Share This Page
