JDM transmission for 01 civic?
ptacc9
Hi,
I need some help in diagnosing a problem. I have a USA made 2001 Civic LX Sedan Automatic. The transmission from my 01 civic went out and through ebay I bought what they called a "JDM Vtec transmission Civic 01-05". Im pretty sure it's a transmission from an 04 or 05 civic. Anyway, I was assured that I would have no compatability issues. Before explaining what is happening, I am wondering if I have to reprogram the ECU by using a Japan Made civic 04-05 transmission in a USA made civic 01 car. Am i missing something else??
Recently my cousin installed the transmission for me and I got a check engine light with a P1705 code which is for a malfunction in the Neutral safety switch or Transmission Range Switch. One of the symptoms I noticed was when I put the Select Lever on Drive (D), the lever was actually between D and D3. Also when I tried to move the lever to D3 it would just skip it and go to the 2 position both on the lever and the dashboard and the D light on the dashboard started flashing. Nonetheless I erased the codes and took it for a test drive. Everything was good, until I felt the gears shifting like crazy when I slowed down and I got the P1705 code again. Also I felt a strong vibration when I reached 45mph or more.
After that, my cousin replaced the Transmission Range Switch and Wire harness with the ones from the old transmission. This time I didn't get the code and took it for a drive. I haven't tested if the vibration is still there. What I did notice though is that the Shift Lever is still between D and D3. When i move the lever to the D3 position, the D3 light in the dashboard turns on but quickly turns off. When I take my hand off the lever, it goes down to the 2 position which is no longer illuminated in the dashboard. I also am no longer getting that D flashing light anymore.
What we're gonna do next is check if the switch was adjusted correctly.
Any help with this or any suggestions are appreciated. This is driving me crazy!!
Thanks and sorry for the long post.
mahalo
formerly egninesallday
my only geuss is the gearing on your new transmision is different than what your dashboard reads cuz its set up for your old tranny im just geussing though
ptacc9
Thanks for the reply! Can anyone verify this? And if so, how do I proceed to correct it?
DarkCreep
D16Y8+T
I heard theres many differences between the 01-03 and the 04-05. Hopefully you get your problem fixed.
ptacc9
I always heard they were interchangeable, at least the automatics. Anyone who can provide more info on how I can resolve this, I would deeply appreciate it.
Thanks to everyone who has responded so far!
