Knock Sensor Removal!!!!!
89SiHatch
i wanted to ask see if anyone has removed a knock sensor off a B16a and if there are any torque spec once you replace it.
Also what tools to use to remove it engine has been dropped into a 89 Si hatch and space is tight.... ratchet with deep socket? seems like the answer but someone has to know what tool to use.... crescent wrench maybe? :smackself :smackself
EG-Owns you
Twin Tech Owns Your s**t!
um its prob best just to keep its allways good to have
89SiHatch
shoemaker617 said:
Why would you wanna remove the knock sensor? you replacing it?
FORGOT TO SAY, :roll:
i am replacing it its throwing a code23on my ecu and im about to get new one i just have no idea what to use to remove it
SuperSize
japanese muscle
as far as i know you need to drain your coolant cuz if you take the sensor out coolant will spill out of the hole
io_303
NIFOC
nope no coolant no nothing... all a knock sensor is, is a mic attached to a block to detect harmonic freq. of a knock. I used slip joint pilers but a large socket will work but i dont know the size
89SiHatch
ok ill try the plyers and ill try some sockets i know its bigger than a 19 for sure if anyone knows?? any torque specs?
shoemaker617
It all depends what you could get in there the easiest, i never had to remove my knock sensor ,so i would guess deep socket and a ratchet.
12.8:1 Ls/vtec
IT'S OVER NINE THOUSAND!!
Very possible but there are a few other things that your ecu monitors as to if vtec will engage or not.
