san007 New Member May 23, 2010 #1 HI guys, I my 94 civic low beams aint working, I checked all the fuses all seems to be good, my parklights works and full beams works. I have even changed the bulb but no luck! can any1 suggest any ideas?
Deezy silent partner Registered VIP 5+ Year Member May 23, 2010 #3 If your sure the fuses/bulbs are good then, then like Lotz says, you probalbly have a bad switch.... .....And here is a good DIY on how you might fix it......Click here
san007 New Member May 24, 2010 #4 Hey Guys , Thanks a lot , lots of info ... will have a go at it tommorrow and hope that is the culprit!!!
x23Curtis23x New Member 5+ Year Member May 25, 2010 #5 mine did the same thing it was the switch inside the car just go to a junkyard and pull another switch mine works great now
RonJ Banned May 25, 2010 #6 x23Curtis23x said: mine did the same thing it was the switch inside the car just go to a junkyard and pull another switch mine works great now Click to expand... Have a look at the DIY link that Deezy posted. It could have saved you a trip to the junkyard.
san007 New Member May 29, 2010 #7 I got the whole switch forfree from a mate, so i replaced the whole switch but no luck ! any1 got any suggestion?
RonJ Banned May 30, 2010 #8 Click the Fuses link in my signature. Use a test light to check for voltage at both top metal tabs of installed 10A dash fuses 21 and 22.
