I have a T28 that I plan to install and run low boost in the range of 4-6 lbs on my D16Z6. I have researched quite a bit and think I am almost ready to do the install. The only thing that intimidates me is the fuel/engine management. I have gotten mixed reviews about what is necessary to run modest boost in terms of management. I have blue top DSM injectors, HKS Turbo Timer, and Zeitronix datalogging so far in terms of management. I have read that my stock system could handle the modest boost intake as long as I am under 8 lbs. Is this right? How about the map sensor? Would the stock fuel pump power the DSM injectors fine, and are the injectors even necessary? Would ecu chipping be needed? This is my first boost project and I'd appreciate it if someone could guide me in the right direction.
Current Part List:
Garrett T28
Charge piping, couplers, and clamps
Front Mount Intercooler
DSM Blue Top Injectors
Zeitronix Datalogging
HKS Turbo Timer (not needed but was free so eh)
DSM BOV
Needed:
Manifold
Downpipe
4-6lb Wastegate
Oil Feed/Return Lines
ECU Chipping?
Fuel Pump?
Missing Link Map sensor override?
Current Part List:
Garrett T28
DSM BOV
Needed:
Manifold
Downpipe
4-6lb Wastegate
ECU Chipping?
Fuel Pump?
