OK so basically its my girlfriends 91 CRX Si that she bought without telling me...she got the car in Nov. 2011...it ran ok at first...in the winter it ran very good until it got warmed up then turned to s***...now that its summer its pretty much s***ty all the time...i need help quick so that we can have 2 dd's
Problem
The problem seems to be mostly at low rpm's where it boggs/ lags really bad...when i push the gas all the way down with the clutch in it takes almost a full two seconds to rev up to 2000rpm...obviously this sucks at stop lights...once i get it over 3000rpms and go thru gears keeping a higher rev it runs alot better
1st gear seems to be the worst...then second gear...the higher gears run better however between 3000rpm and up it has a little bit of a stutter kind of randomly...also when i am cruising in 3rd and 4th with just a little pressure on the peddle it has some random stutter/cut outs
First attempt to fix
After buying the car i thought it could use a tune up...i got new
Timing belt
Water pump
Drive belt
Coolant
Cap & rotor
Coolant temp sensor
Intake air control valve
After all that it ran a little better but not much...i went to the local honda stealership and talked to an older mechanic for a minute and had him play with the throttle a little bit...he thought it was the MAP sensor
Second attempt to fix
First off phuck paying a s*** ton for a new MAP...and honda doesnt even make the part anymore...so i went to the junk yard and got every MAP off of every civic/crx i could find between 88 and 91(4 MAPS)...went home and put in two different ones, reset the ECU and it still isnt running good
After changing this MAP it ran a little better...if i drove it with a racingish style and kept the revs high it was fine...still sucked for a complete stop...if i drove it conservatively it still bogged...also had almost no throttle response especially from 0%-20% from a stop and if i was cruising at about 40% throttle and stepped on it all the way down
I can only think of a couple other things...tomorrow im going to try the starter fluid in a vac lines to see if theres a leak...or could be the TPS
Anyone have any other ideas?
Also if you guys are thinking TPS what are my options...i dont really want to replace the throttle body but i also dont want to rip up the one i have to put in a new TPS and risk ruining the new TPS or TB...anyone done this...im wondering how touchy a new TPS is when installing to the TB
Thanks for any help...sorry for the
Problem
Timing belt
Water pump
Drive belt
Coolant
Cap & rotor
Coolant temp sensor
