various pics though things change daily, new seats in the works fell asleep early 2night needed a nap so they wll wait till tom and new cam is on the way
have a few things in the works
ENGINE
1998 B18C block w/ 2000 B16A2 Civic Si head
Comptech IceBox & filter/ AEM ITR CAI arm
Vortech fuel pressure regulator
B&M fuel pressure gauge
JDM Civic Type R intake & exhaust camshafts
TODA Racing adjustable cam gears
RC Engineering 310cc fuel injectors
JDM Civic Type R oversized pistons (12.15:1 compression ratio)
ARP rod bolts
Comptech TIG welded 4-2-1 stainless steel exhaust manifold
RandomTechnologies high-flow catalytic converter
Greddy / SpoonSports (Spoon N1 muffler/Greddy B-pipe) custom cat-back exhaust
Sohfast lightened & balanced OEM crank pulley (shaved A/C & PS)
DINAN programmed ECU
NGK spark plug wires
Mugen low-temp thermostat
Fluidyne radiator (Integra)
Fluidyne high pressure radiator cap
Integra Type R water pump
Integra Type R oil pump
Mugen reservoir cover
hondata s200 with p28 (have hondata, waiting on new ecu old one had obd2a plug on it...
TRANSMISSION
1996 Integra GSR transmission w/ 2000 Type R axles
Sohfast (10lb.) lightened & balanced flywheel
Integra Type R pressure plate
ACT 6 puck ceramic clutch disc
B&M short shifter w/ Energy Suspension bushing
SUSPENSION
BBS RX 16x7 wheels
Yokohama ES100 205/45x16 tires (Brand New)
Tokico Illumina 5-way adjustable shocks
Skunk2 coilovers (stiffer Integra spring rates)
Integra Type R pillow ball mount bushing
Energy Suspension bushings
Integra GSR front upper tie bar
SpoonSports rear upper tie bar
Integra GSR rear lower control arms
Civic CX non-power steering rack (19:1 ratio)
Full race Traction bars
BRAKES
Integra Type R master cylinder & booster
Goodridge stainless steel brake lines
AEM/Nissin front & rear pads
PowerSlot rotors (front)
INTERIOR & EXTERIOR
Sparco pedals
Sparco Mugello steering wheel & hub
JDM Integra Type R shift boot
Acura RSX aluminum shift knob
Eclipse CD player
Pioneer(front) & JBL(rear) 2-way coaxial speakers
PIAA bright white headlamp bulbs
clear corner lamps
"SpoonSports" styled power side mirrors
WingsWest RS side skirts
WingsWest RS duckbill rear upper spoiler
Benen Industries "SpoonSports" styled carbon fiber chin spoiler
Sparco Torinos (about to go in)
ENGINE
ARP rod bolts
TRANSMISSION
SUSPENSION
BBS RX 16x7 wheels
BRAKES
INTERIOR & EXTERIOR
Sparco pedals
Eclipse CD player
clear corner lamps
