My B16 Fully built build thread!!!!!
watisjdm
Clit Commander
well ive started to crack down and started buying parts like a mofo so heres what the motor is gonna come down too
block:JDM b16a (fully converted to obd2 by me)
CTR( PCT) pistons std bore
Shot peened b16a rods
mircopolished and balanced crank
shaved oem crank pulley
all new gaskets and pumps and etc
moroso oil pan
arp rod bolts
arp headstuds
moroso oil pan
head:jdm b16a head
crower dual valve springs and retainers
crower stage 3 camshafts
cometic 2 layer headgasket
password jdm cam seal
cant decide but either skunk 2 or hks cam gears
3 angle valve job
cant decide if i want port and polish or not
oem b16a valves
Tranny: Jdm b16a
fidanza 7.5lbs flywheel
arp pressure plate bolts
arp flywheel bolts
clutchmasters stage 3 clutch
im sure i got alot of other s**t but i cant think of it
hope to have it in sooonnn
if im correct compression should be around 11.6:1 or 12.1:1
Ls-HatchBoy
Honda Whore
sounds like youll pull some okay numbers, but the bad thing about honda's you have to boost them to get anywhere lol.
watisjdm
Clit Commander
ehh not really it should do around 200whp
which is enough for me
thisisoriginal
pete's cheese nugget
exactly...I can't even drive my car, I stand behind it and whip it because i dont have boost
dumb.....
fronomo
^its the JDM dual oil pan setup...allows for 8 quarts of oil for better oiling ;)
Drackonn
looks good, I agree you should be around 200whp from what I have seen in other b16's, good luck =)
BlackHopeDC5
Is Black Again??? :shock:
what are you tuning with? why did you go with a b16?
umair
when do you think it will be done? make sure you post up some videos. =)
BTW nice set up, its going to sound really nice and it should be pretty quick.
Blazed
f**k The Powers That B
nice build up but i doubt u will see 200 unless ur on a dynapack..bore that bish out :P
Ls-HatchBoy
Honda Whore
He should put down around 190 WHP, or somewhere in that range. And 190-200 is a nice amount but your not gonna kill mustangs, camaros and such. It will be a nice set-up, and the good thing is it will be more reliable than a boosted car.
watisjdm
Clit Commander
Going-West
Tree people on my radio
I would have gone with a 1.8L block since you're rebuilding the bottom end anyway, but should be fun. Good luck man
