Raise the car, take off front wheels, LOOSEN the nut on top of the ball joint and use a ball joint separator(google it) to pry it loose. Put the new one in using the reverse order, and don't forget to get alignment afterwards.
Do you mean the ball joint press?because I got the seperator but I'm trying to replace it with a new one....and the bolt is in the bottom not the top...
