wtf are you reading?, he asked what he could use instead of the coilover wrenches . not how to get to his coilovers and when he needs to get a alignment.Just drive up on some 2x4's. It is highly recommended to get an alignment everytime you adjust the height on coilovers.
wtf are YOU reading? He said he needed to raise the car in order to work on it. Which is why I said drive up on 2x4's. Which is also why I recommended not to adjust the ride height to simply work on the car since you should get an alignment whenever you adjust coilovers.wtf are you reading?, he asked what he could use instead of the coilover wrenches . not how to get to his coilovers and when he needs to get a alignment.
as someone said above, try a hammer and flat screwdriver. put a rag over the tip of your screwdriver so when you miss you dont damage the coil
